TSIfreek
- 1,674
- 18
- Dec 14, 2003
cary,
Illinois
Hey guys. I just got some logs on my new motor and have weird knock counts. I have knock up to 43 and then goes to 0 counts its not a spike but more like a decining mountain. My boost gauge is not reading corectly so I just hooked it the vacume directly to the WG so I should be seeing 7-10 psi. I got a lot of counts turning on to my street at low RPM for no reason. I have a new knock sensor as well. I have tryed turning down the timing to around 4* and still get it. I am running a 255 HP pump with a stock reguator, stock 1g unhacked mass and stock injectors. I have blocked off the EGR and I have just read that removing the EGR causes knock at low rpm light load conditions. Anyone heard of this? I am not ruleing out phantom knock from outside the engine and may be the problem. Anything else I should look into. Thanks for all you help. Any advice would be very helpfull.
