High idle when clutch is pressed
BLACK'98DSM
Moderator
5,523
3,057
Feb 9, 2019
Alabama
This only happens when the car is in motion and I push the clutch in. It likes to sit at 2k rpm. Occasionally it surges between 1700 and 2200. I noticed that this only happens once the car is in motion. If I start the car and let the choke cut off, then it idles at 750 rpm, just like it should. I'm not sure why being in motion makes a difference?
I just installed a new throttle body with new tps and new iac sensors, and I hoped it would fix the issue, but it only made it worse! Does the iac need adjustment? Or what else could it be?
I had to unscrew the IAC tip about 3 turns and that really let it idle down. It still sits above 1k when in motion, but it is much better than before.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
