knochgoon24
DSM Wiseman
- 6,135
- 98
- Jan 29, 2008
Troy,
Michigan
I just replaced the throttle shaft seals, now I can't get my idle below 1400 RPM, even with the BISS screwed all the way in. Backing the BISS out makes it idle surge. I'm pretty sure the TPS is correctly adjusted, since the idle position switch shows closed when I'm off the throttle and switches open as soon as I press the gas. I'm now pulling 20 inHg which is better than my old 18inHg at idle before the replacement. I figure this is due to the new seals, those old ones were leaking horribly. If I'm pulling more vacuum, how do I have a higher idle?
As soon as I put the car out of park/netural (auto), the RPM drop to 750 and sit rock solid, where it's supposed to be.
I logged what is happening on Evoscan. This is just very lightly moving the throttle.
As soon as I let off the throttle, the RPM drop to 750 then climb right back up to 1500. If you need better resolution, tell me and I'll do another log just logging those 3, or anything else for that matter.
I would do a boost leak test, but I'm up at college. I checked all the intercooler clamps and they're tight. All vacuum hoses are also good.
With the TB elbow off look and make sure your butterfly plate is closing properly. If the plate is backwards it'll never seat properly on the TB surface and you'll get all sorts of problems.
