Heres where the oil leak is! What is it? Pic inside
mckc
99
Dec 16, 2004
Overland Park, Kansas
I took some pictures of where the oil is leaking. Does anyone know what this is and how I could fix the oil leak? thanks for your help.
Alright, tell me how that goes. I wont be able to get to my car for a couple of days.
Ok, so today I tried to get that screw out to fix the leak, and I dont know how to get it out. Its tight in there and I dont know what to use to get it out! What a pain in the butt. Does anyone know how to get this screw out?
Try spraying it with some pb blaster let it sit for 30 mins and spray it again. Also helps if you have the engine alittle warm also to release the threads abit more. If that doesnt work you will need to put it on a lift and use a breaker bar, should come out def. with a breaker bar and some leverage from your body weight pushing it forward.
I mean its more in a tight space and I can't get to it. Is there a way to take off the oil pressure sender thing(copper piece) and get to the screw?
take a wench, i think a 12mm if not a 14mm, and bam, the oil pressure sending unit ( copper piece) is loose and ready to be taking off..
