Where is this oil leak coming from? (pic)
You are excatly right... the leak is from the valve cover. Just take it off and throw down a new gasket w/ some silcone and you should be ready to go
thanks for the quick response :thumb:
about how much would a decent mechanic charge to do this? I have 0 tools where I'm at right now, I mean maybe a screwdriver and a flashlight.
the design of the valve cover causes it to actually cut the corners of the gasket off if over-torqued or becomes brittle.
overtorqued as if I kinda shifted into 2nd instead of 4th going 90???
Yeah, all that good stuff is in a different thread. :shhh:
a screwdriver and a socket w/ a 10 i believe.(Could be 8) are all the tools you need. You will need a gasket set which if i recall comes in around $20 or so. So if you take it anywhere and they charge anymore than $50 I would tell them to **** themselves
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
