help with tuning please
sydergstBUiLT
Apr 13, 2009
canton, Ohio
ok i finally jus got my lips running and well . i have no idea how to tune it . i have the apexi afc neo . if posible i need to kno what to tune on it and where to set everything . right now i cant afford to get it really tuned for 200 an hour at burchur racing . so i need to do somthing and get it good enough to where its actualy drivable . or am i just able to unplug the neo and run with out it ? any answers would be very helpful please
You really dont need AFP regualtor unless you stepped up to a 255 wally You can step up to bigger injectors then tune the afc for the bigger injectors it will make a big difference. If you want to run more boost and have a lot of mods your going to max out those injectors quick!
yes im still on stock injectors b.c 1 im still getting to much fuel . 2 i do have an adjustable fuel regulator so i can adjust my fuel pressure. i want to change the injectors but im not gunna change them when im geting all this fuel already.
From personal experience I WOULD NOT GO TUNING ON A VEHICLE W OUT FIRST THE KNOWLEDGE AND SECOND MAKE SURE THE CAR IS IN GOOD MECHANICAL CONDITION AND RUNNING PROPERLY BEFORE THE TUNEI believe stock FP on the 2gs is 27lbs at curb idle that is. If your still running rich w the stock injectors and no tune id say your still having mechanical problems. Have you double check exhaust manifold o2 housing etc for leaks? This is what caused my 2g to have same problems when i thought it was a bad MAF. Also the EGR valves are prone to get dirty and stick open causing excessive amounts of EG and boost leaks.
Heres the link to the page i posted how to check FP on a STOCK setup
http://www.dsmtuners.com/forums/pro...d-then-all-sudden-car-just-jumped-quit-2.html
GO TO POST #39 ( The pressures listed are for the 1g 6bolt setup. Replace the values w 27lbs w hose connected and 36-38pis w hose disconnected.) YOU can probably skip the majority of the steps since the AFPR has a gauge built in. Simply adjust pressure to necessary settings and see where you air/fuel mixture is
To be honest I think you should sell the afc neo and buy dsmlink since you can control how much fuel is realsed. Your fuel pressure regualtor could be off maybe read some threads about the right pressure to set it at
I know if you run rich for to long it can ruin your bearings,the guy i got my car from had a 255 wally running on a stock FPR im running extremely rich so the car is sitting till i get the AFPR installed.
i have 1 more question . how can i tell if i start to detonate ? my windband gage doesnt read anytihng . so i cant really look at that . and i cant hook my laptop up to it yet to see how its running b.c i need a comport adapter. so how can i tell if it starts to detonate?
