GSXeclipsePSI
- 563
- 8
- Jul 7, 2003
New Port Richey,
Florida
Ok, been looking and looking for my oil leak. And still without going thru replacing or fixing everything I have in mind I still have yet to find an answer...
I just got a SAFC-II after trading back my AFC NEO. So 1st time runing good HP out of the enigne in about 10months.
So I ask a question as to can you give me a few ideas to whats leaking!
Problems:
Oil leak - .5 qt 3weeks
Oil leak - Turbo drain pipe. Oil Pan. Wheel well timing cover *black pc.,Oil pressure sender unit to gauge (no teflon tape), Oil spray on bottom of turbo
when using 15psi I could smell oil burning at speeds over 100.
Oil pressure seems low, hiting 100psi or so during 0-60 on 15psi boost.
Retards put 2g oil filter on my 6bolt (SC job)
Also, when I moved to FL I had to get my Waterpump replaced in SC at a shop I didn't trust but had to. They put my balance shat out of phase, I got 40miles b4 a huge oil leak came from the filter housing causing me to bring it back to them. So Oil filter housing could have been damaged by them.. IDK
LOUD LIFTER TICK
-20 psi oil pressure at idle as far as I can tell from the gauge.
- intercooler pipe broke OIL PRESSURE SENSOR (LIGHT), the round part broke off. Trying to jb weld it but no luck. Pipe broke it off again.
--- No oil above intake, no oil on timing belt cover. -----
thanks for the help.
Im also for some reason having the hardest time getting the EBC to have a smooth boost setting on boost higher then 17. Tryin to hit 20 or more it bounces.
I know how to use it, and I got it to go from worse to better the way your told to in the book. But I dont have the BOOST LIMIT SET or REDUCTION for boost limit so I cant see why its hard. I have low boost set at 17psi now and I have 72 in. Then you try them same setting on HIGH and it dont work. Then try going to 20 by got to 85 which is alot compaired to before. I have had this boost controller for 3yrs.
Profec-B II
Problems:
LOUD LIFTER TICK
Profec-B II
so yea, still working on that plan
