Help with oil leak
Nautica985
320
Dec 2, 2002
Baltimore, Maryland
Oil is leaking from the balance shaft sprocket. It does not leak at idle, but when I raise the rpm's oil comes pouring out. Is it just the seal or could there be something wrong inside the engine? If it was just the seal I would think that it would leak at idle.
anyone? I was looking at some pictures and there is a balance shaft spacer and bearing, could it be one of those? I dont wanna have to take the timming belt and every thing else off to replace the seal and put it back together and then find out its not the seal.
More than likely it is the seal. Only way to know for sure is to pull the front case off, though. :(
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
