Help with next mods
4geze63
891
3
Nov 18, 2003
edmonton,
Here is my currect list
K&N
Intake
small16g
match ported o2
2.5' turbobackexhaust (highflowcat)
turboxs RFL bov
Now I dont have any fuel support so I have the mbc set at 15psi and the car seems fine.
I just would like some input on what you guys would upgrade next say inorder of importance. I was thinking
1.walbro 190/255
2.upper ic pipe W/2ng gen TB elbow
3.evo exhaust manifold
I wont really go past 15psi for awhile so do I really need injectors now?
and also how much better is a testpipe over Highflow cat?
thx :p
do you never want to go over 15 psi? if so maybe you dont need injectors....
Test Pipe (I have a test pipe :p, its greatness.)
Datalogger and AFC
FMIC
Id say you will be god on injectors for awhile,but if you do plan on boost any more than 15psi. Get an afc and datalogger. If not then adding the other stuff and not putting them to use would be pointless. (money well worth spending)
2. Exhaust manifold evo or 2g is fine (with good port work. Does wonders)
3. 2g tb elbow and uicp
4. fuel pump ( I say if your going to do it mind as well go on and use the 255)
5. fmic is nice to have. (doesnt take long to heat soak that sidemount Supra sidemount could possibly work depending on your goals)
Oh and a brake upgrade if you havent done so already. (want to be able to have good stopping power) I also say good tires for traction are in your future as well. heh
Im assuming you have done all the free mods, and have guages. Well hope that gives you a good start. ;) Goodluck
