help with diagnosing MAF failure
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
hello everyone i am trying to attempt to see if my maf has gone out. I was able to boost fine to 20-21 psi no problem then one day when i went out it begins to boost but then cuts out. Not quite like fuel cut but very similar. It goes out then begins to boost again then goes out again. It wont allow me to post the log since i posted it in alternative thread but i will post the link to that thread, the log in question is the one labeled boost cut log.
http://www.dsmtuners.com/forums/tuning-engine-management/387474-help-tuning-dsm-link-2.html
sounds more like a boost leak too me. But if you want to have you maf check take it to a dealer and have them test it. the just check the electrical resistance too see if its in spec. They should be able to do this at like an auto zone or something like that.
Uh I don't think its a boost leak. Everything has been checked and there are no large leaks whatsoever. There may be some tiny leaks but its definitely something that is cutting fuel supply or something along those lines
Sent from my HTC EVO using Tapatalk
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
