Help with couplers
dsmdizzle
105
Jan 7, 2006
Ogden, Utah
The dsm I am buying needs intercooler couplers. It has the ebay ones that are not silicone and they pop off too easy. My question is, is there a way for me to get these to stay on without buying 4 ply couplers. I will eventually, but I can not afford it right now. The car runs 16psi on a 16g and it has tbolt clamps. Advise would be appreciated!
He's already got them. Check if the couplers are too short, that's a big reason why mine are blowing off right now. Beyond that you can get them beaded which will help out immensely. If you can't find anyone to do it then the most common ways of keeping couplers on include hairspraying the pipes first, jb-welding the beads on yourself, or (what I might do)--drill some screws through the pipes to serve as a lip. Let me know how it goes.
It was a pretty liberal coating(s) on a friend's car. Unfortunately, now we also can't get one off.
I'm currently running 15 psi (creeping to 20 above 6k and blowing couplers there).
If they're popping with t-bolt clamps installed, the couplers are probably too short. Pressure doesn't pop them off, but the pipes moving around from a rocking engine will do it. Try longer couplers.
