Injen Intake Couplers???
Sp00lin16g
51
Jun 29, 2015
Cleveland, Ohio
Does anyone have or know where I can get couplers that will fit the injen intake .. my current couplers are hard and may be causing a boost leak??
Thanks guys
That seems strange. My Injen intake couplers are all before the turbo & would make any difference for a boost leak. Could mess with MAF metered air though & cause running lean maybe. Anyway couplers can be bought from just about any one of your favorite vendors & there many really goods vendors on here & support our community that you can go to & support. The big one is 4in & the small is 2-1/2.
ok thanks for the info .. the larger coupler is an oval, will that work?
The 16g intake inlet is 2.5in?
Well I think so. Mines on my car so I can't measure. it may be 2-1/4. You should measure your old one to make sure.
Edit: It's 2-1/4. I went & measured my Boost Leak Tester coupler. It's the same size because that where I weak test at.
Just picked up a 2 inch couper and t clamps on ebay for 5 bucks. Guess I'll have to give it some love to get in on. Lol
Very nice ... I'll measure and see what I'll have to order. Do you just get one off ebay or a aftermarket site like the approved vendors?
If i remember correctly its just a round coupler thats then oval, memory is telling me its a 100mm dia but its been a few years since i actually did this check so sorry if im way off
Siliconeintakes dot com will have anything you ever need... before speed density i got a 45 degree hose for bov return too...
Not trying to steer you anywhere just have had great experiences with them
Good call on the siliconeintake ... they're sold out of the 2.25 in tbolt clamps ahah and I needed one
Pegasus Racing is another company I've had good experience with regarding silicone tubing. My BOV mounts in a rather unusual place thanks to the FMIC so I had to get creative with tubing/routing. Found what I needed from them. Also needed a longer straight section to clear the P/S cooler. My only complaint-only black, red, or blue colors. Lol. (I like pretty colors!)
You can use a spritz of hairspray on those couplers, helps them slide on and is a light adhesive to really help them stay put. A hair dryer too, but I always get a awkward/annoyed look from the hairdryers owner when I'm using it for something like that .
