help wiring harness in bay
xander061
181
Jan 19, 2010
Lexington, Kentucky
Im in the process of putting a 91 tsi motor in a 92 3esi and have a few plugs on the engine wiring harness that im unsure what they connect to. I have the service manual but it dont have with connectors. One is behind the intake on the drivers side near where the knock sensor connection would be on a tsi harness. The second is the connected close to the firewall behind the TB that comes off only bout an inch or 2 from the firewall. The third ill take a pix of to explain it. Ill have pix of the others later 2dayto im at work now.
its not the knock sensor the harness is a 92 n/t one and they didnt have those on my tsi harness theres the knock sensor and then one right next to it which is what this is
First connector has a blue w/the yellow strip and green w/the bkck strip. The second connector has a brown w/the white strip and solid red wire
First one is this.
Second picture shows two connectors; the one on the top is this.
The other connector is for the EGR solenoid on Cali-spec emissions vehicles. Sorry, no visuals on that one.
