help transfercase
Redfwdsm
299
Nov 29, 2008
brick, New Jersey
i cant get the bottme two bolts in my transfer case.
for what ever reson every bolt goes in by hand without the transfer case on but when it is on the bottme two will not go in one long and one small but if i take the long one and put it in the short hole it goes right in anyone know what to do or ever run into this before? :banghead::banghead::banghead::banghead::banghead::banghead::banghead:
Take the transfer case off an put the bolt all the way in. (until it bottoms out). If it works, then you have the bolt in the wrong hole?
If not, then you stripped the hole.
Do not bump your threads.
Please use spell check, proper grammar, punctuation, etc. in your future posts.
