Dhan
Supporting Member
- 3,772
- 192
- Apr 29, 2010
Denver,
Colorado
Replacing the blance shaft belt on a 4G63 non-turbo Talon I picked up recently, but I'm having trouble removing the outer crankshaft sprocket that allows me to get to the balance shaft belt.
Is there any way to lock the crankshaft, flywheel or the transmission so that I can take the bolt off? Turning the bolt now just turns the crank. Also, is this bolt a reverse thread?
BTW engine is a 6 bolt and non-turbo.
Sorry if this has been covered already somewhere. I looked on vfaqs, but it describes a method for a vehicle that runs so it won't work for me.
