caseyk
- 206
- 4
- Jul 17, 2008
Anderson,
Indiana
Im looking into trading my 96 civic slow single cam for a 1g tsi awd with plenty of mods.
Heres the deal though, it developed some sort of knock recently. Its been parked ever since he first heard it knock.
it doesnt knock at idle, sounds perfect. He said it only seems to develop this knock after about 3krpm.
Ive had a 2g do this to me before. It happened to be the balance shafts. I eleminated it and noise went away.
He told me if I liked it I could pull the oil pan off and check whats going on.
Id like to pick it up if it is just balance shafts. The car is VERY clean exterior and interior.
modlist of the car:
The car is currently tuned on 25psi running on e85
110k on shell. Less than 25k on motor and trans
ACL race main and rod bearings
All arp hardware
Mls Headgasket
20g turbo
PTE 1200cc Injectors
ETS Street FMIC with short route piping
Spec stage 3 clutch
Fidanza Flywheel
Ecmlink v3 Full
Forced Performance Stainless o2 housing
GM maf w/ecmlink gm maf cable
Forced Performance 255lph pump
AEM wideband and autometer 30/30 boost gauge
Hallman MBC
Shaved and powder coated valve cover
2G Dual Piston Brake Calipers
Kyb Gr2 struts
Fidanza Flywheel
3" Straight pipe exhaust
All new axles, new slave cylinder, new brakes and rotors, lots of new parts
New bfgoodrich geforce tires
18 inch wheels
modlist of the car:
All arp hardware
Mls Headgasket
20g turbo
Spec stage 3 clutch
Fidanza Flywheel
Ecmlink v3 Full
Hallman MBC
Kyb Gr2 struts
Fidanza Flywheel
18 inch wheels
jk, go take a like at it and see what it sounds like maybe pull the pan. Are you doing a straight up trade
guy, I would go take a look at what we got. Drive it, Listen, and as mention above, pull the pan. You will be able to tell, if you drop the pan and play with the bottom end.
Trade for a Honda to DSM, any day!
