HELP no start
worldindustri86
Feb 17, 2005
lancaster, California
WTF ok got a 2.0 turbo in but it cranks, and cranks, and cranks but wont turn over its half ass turns over but not enough to idle whats up with that? i know its not fuel cause i know theres pressure cause i benn sprayed in the the face many times checking....and on top of that the motor i have was caught on fire before i got it but everything has been replaced so i dont know why i wont turn over plenty of spark to please any help would be appreciated thanx... i just want to drive! OO and ecu is new..
Check your crank angel senser and all relay's fuses but most likly it is your crank angel sens
Did you do the actual spark test or are you just guessing. There can be only no spark, no fuel or bad compression. If you're 100% sure you have spark and fuel, either check the timing belt like many have suggested or do a compression test. Good luck.
Did you blow your main motor fuse because of faulty wiring somewhere (like a boost controller, gages, or something)? Stick a screw driver in your plug wires to see if theres spark, then make sure you have spark in BOTH sides of the termanal.
