Spoolin98
- 1,646
- 24
- Feb 1, 2004
Easton,
Pennsylvania
Hey guys I need some help getting my brothers car running right. To make a long story short, he bought a 91 talon tsi awd not knowing that the axle bracket bolts were snapped off inside the block. I ended up pulling the motor to extract the bolts. I replaced the intake manifold gasket because there was a huge vacuum leak. I dropped the motor back in and ran into a few problems.
#1
The CEL is on only at idle, when you give it throttle it turns off. Anyone have this same problem? How did you fix it? I am not around the car. I'm away at school.
My brother bought a datalogger, but cannot seem to get the thing to work. First the software sent by pocketlogger was faulty, now he got the software working, but the palm keeps telling him to check the connection. He followed vfaq for the installation of the logger cable.
#2
The temp gauge does not work since I reinstalled everything. I took the car to autozone, the guy there said he knew a bit about dsms, he looked at the car and said it had a 2g thermostat housing, and the person bent these pins to fit this female connector on (attached pictures). It looks like the part being pointed to has been replaced, there is some sort of sealant around it, the grey stuff. Is this a 2g housing? I dont understand why it is not working now, because it was working before.
#3
The car stutters around mid range rpms. The only thing I touched were spark plugs, wires, and the coilpack(which was swapped onto another IM). I gapped and put new plugs in, that did not fix it. The car did not do this before I pulled the motor. I did a boost leak test, it seems the only place there is a leak is the throttle body seals, which explains why I need the BISS screw all the way in to get the car to idle correctly.
Sorry for the long post. I just want to get this car running right already.
Thanks in advance.
#1
#2
#3
Thanks in advance.
