ECMlink Help, installed cams and now engine won't idle
maneotis4g63t
Mar 20, 2012
Murray, Utah
Guys or Gals I need some help please.
A few weeks ago I installed some DKS 272s. My car was idling just fine before we put them on and now it won't idle to save it's life. I checked and mechanical timing is on. Boost and vacuum leaks are nonexistent, ISC motor is good, ECU is in good shape, and I reset fuel trims, and no matter what I do with the biss screw, it won't idle. I don't understand what is going on. Has anyone had this problem or could someone offer some tips on why this might be happening?
Here is a log I took tonight. The only way I could get it to stay running for more than one second was to lightly put my foot on the gas. The times you see it die in the log is when I took my foot off.
Any help would be greatly appreciated!
You may have to adjust your ve table or maf comp. Im on my phone so i cant upload log. Try raising them slightly. Also check your idle switch through link. Maybe have to adjust a bit. I have the same cams and had to tune my ve table im running s.d though
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
