2G Help identifying automatic transmission shift solenoid for 1997 Eclipse GS
mutant_spider
Sep 28, 2005
WestChester, Pennsylvania
I need help finding the right transmission shift solenoid for my 1997 Eclipse GS. I lost reverse; I tested a known-good TCU and that didn't fix the issue, so I'm looking to replace the TSS. I bought the ATP Automotive TE-6 Transmission Control Solenoid from Amazon (https://smile.amazon.com/ATP-Automo...utomotive&vehicleId=10&vehicleType=automotive) as it said it fit my car, but the unit doesn't go on and it's clear the holes aren't in the same spot (see photo). All the images I see online don't look like the TSS from my car.
Any help identifying the correct part needed would be greatly appreciated.
Thanks.
That is called a solenoid pack and I don't think that it's going to fix your reverse problem. First you should check your fluid if it's at the correct fill mark and also does it smell burnt cause usually the reverse clutches burn out. Another thing is did you scan it for any codes?
The solenoid pack got redesigned in 2003 to get rid of the ratcheting noise. It could be that is just the newer model and that's why it doesn't match the original
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
