1G AutoMatic Transmission Won't Shift
stcloudgsx
Sep 5, 2005
St. Cloud, Minnesota
My friend just purchased a '91 gn auto gs-t for real cheap. The car will shift into park, neutra, drive, reverse all perfectly fine. But once in drive, the car seems to be stuck in like 3rd gear. It bogs off the start and will just hover around 3k to 3500 rpms once up to speed. I've been told it may be the TCU but I am just making sure this is most likely the problem. Any info is greatly appreciated. thanks
Anthony
exile said:
That's called Limp Mode, the car won't shift out of 3rd gear, check out the automatic transmission forums for help on that problem. http://www.dsmtuners.com/forums/forumdisplay.php?f=62
:thumb: Either way its electrical, either being the TCU or a sensor on the trans itself. I would take it to get the code pulled if you dont see anything on the transmission not plugged, split cut or out of wack.
If the old transmission was not in limp in mode, check that you are sure you did not cross the pulse generator plugs with the shift solenoid plugs. They will interchange but with exactly the results you just posted. If it's not that, you can do like mike and exile said.
Good Luck
please, PLEASE do not take it somewhere to have them pull TCU codes for you. I am pretty sure the Mitsu dealer here in town charges over $50 to check TCU codes. Look here:
http://www.plymouthlaser.com/tcucodes.htm
All you need is a multimeter, analog is best but digital will work. There is also a chart on that page that shows what the corresponding code means.
If it turns out you need a new TCU, let me know... I have a 2 plug TCU out of a 1g that is in AWESOME shape. Will let it go for $50 shipped.
Hope this helps!
ADAM
definitely!
i wasnt trying to bash you, dude... its just very simple to do and it can really save you some $. very important, to me, at least!
let me know what you find out!
ADAM
It's most likely the TCU.You can pull it and look inside for a leaking capacitor just like you would an ECU.It sounds like you're in limp mode.Positive battery terminal making contact with the hood eats a lot of TCUs,ECUs too.
you are correct as well. i would try to pull the tcu codes first since it doesnt require removing the tcu. then if you arent getting anything, pull the tcu and pop the cover off. if the caps are leaking at all or there is any kind of corrosion on the board, you will eihter need a new tcu or to have your fixed.
like i said before, if it turns out to be the tcu, im pretty sure i have the exact one you will need for $50 shipped.
again, man, let me know what you find out and if you need any help with this!
ADAM
Had the same problem in my 90 Talon
all I did was spend about 30 minutes
changed the fluid and cleaned out the gears
It worked perfectly
The person who sold it to me, sold it because the tranny was slipping...
she said that she tried everything
so I got the car for $575
it took about 30 minutes and the car was perfect!
Lots of people dont know how to take care of a car!
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
