automatic transmission shift points
chukolac719
67
Feb 6, 2012
Leadville, Colorado
so i have been having some issues with my transmission. it's a A/T if you press on the gas pedal lightly it will shift properly, but if you want to take off quick it wont change gears untill it hits 5,000 rpm!!, is this a vacuum problem?? the fluid is good and it has a bottle of Lucas in there and still.:cry:
That's a good thing, the way it's supposed to work. The faster you tell the TCU to accelerate the longer it will hold each gear and shift higher in the power band.
Drive like a blue hair and the TCU will shift at low RPM and save gas. Go to full throttle and hold there and the car will shift at 7000 RPM.
At WOT my Talon will shift at 7K, to 2nd at 40 MPH, to 3rd at 70 MPH, and in Montana where my Avatar was taken, to 4th at 110 MPH.
Happy tax day.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
