2G 98 Eclipse Spyder GS shift solenoid
Icepick1
Jul 11, 2024
Melba, Idaho
My 98 Eclipse Spyder GS has a check engine light on. The error code is P1750 (shift solenoid). The car would shift through all gears smoothly until the transmission fluid would get to temp. Then it shifts from 4th to 3rd then back to fourth until a couple of days ago. Now it shifts from 4th all the way down to 2nd. I need help locating the shift solenoid so I can replace it.
they are inside the transmission.. you need to drop the pan and take the valve body off to get to them..... BUT!!!! before doing that check all wiring going into the trans.. if the wire is freyed or not making a good connection at the plug that is a easier fix and alot faster to fix ..
Ok thank you so much. I will definitely check all the wiring first.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
