Help Identify Bullseye turbine housing?
sweet97
2,386
18
Mar 6, 2004
auburn, New York
I have a Bullseye turbine that was returned by AGP on a warranty repair. This is a good turbine that someone could use. On the center section side on line with the internal wastegate flapper is cast "TM" with "G3" stamped next. The size of the exducer is about 2.11x/2.22x". It could possibly have held a t-31 or stage 3 Garret(?) turbine wheel. Can someone help identify it with the info provided? If you have a Bullseye turbine you could check for the stamping and if you know the specs of your turbine wheel please list the size so I could possibly identify what this turbine would fit. Thanks much in advance! Mark
PS: I will also contact bullseye. Could have come from the AGP-RS60T Turbonetics turbo's they sell. The size looks quite close. The exducer is 2.23 and inducer is 2.56 on the 60-1 that I bought from AGP. Hope this additional info helps.
I have an AGP RS60T and all the markings you mentioned match mine to the "T". The RS60t comes with a stage 3 T3 wheel(t31).
Thanks guys, thats what I thought it was for. Not sure who could use it but will post on the Buschur forum as I cannot get tthe classifieds to work here. Thanks again. Mark
