HELP! Bullseye Exhaust Housing Sizing
spendone
403
Oct 16, 2003
Philly, Pennsylvania
I know this topic is killed to death but I am still confused on what will actually on. I have a HX40 and what can I check to see if the bullseye housing fits. Like I said its a HX40 with 8 compressor blades on the inlet. On the exhaust housing its held on to the center section by 4 bolts. Theres no tag on it so no numbers are available. It does have the Map Enhancement Grooves on the intake side though.
The best thing that you could do is to call up Bullseye in the morning. Since they make they turbine housings and HX turbo's, Im sure they will help you w/ ease. I have been to the Bullseye building and was treated w/ respect and they were very helpful. Call and ask to talk to Dan, or David, whoever is available. A lot of the times, a girl will answer phone, and Ive seen her, and she is hot!, Like it matters, but just an FYI.
Ask for Dan or David, and they will be very helpful.
In that case forget Dan or David, i want to talk to the girl. Hahahha, yea Ill have to probably just call my buddy thats a bullseye dealer and see whats up. Thanks for the info though.
I spoke with Dan today. Just if anyone needed to search this info in the future. All HX40's will fit the Bullseye Exhaust Housing.
I also was able to get my HX50 to fit the HX40 Turbine housing witha little machining work too. Dan did mention that you would have to have a huge exhaust and wastegate to relieve all teh back pressure.
