Help I Have Oil All Over My Motor...
1997RS
211
Dec 4, 2002
Little Rock, Arkansas
Please I need help quick. I eliminated the emission as show at taboospeedshop.com and now I have OIL all over the engine compartment being spread out by the sprockets. What could have happened here??? Do i have a cracked head??? Did I blow a seal??? I hear a hist coming from around the sprockets but cant see what could be the problem GSX is stopped i wont drive it. But sure need help in order to trouble shoot it and fix it ASAP. Thank You Guys I need all the help possible Thanks.
-George :(
That sounds like you eliminated the PCV Valve & you are sending BOOST into your Valve cover. You may want to take a BETTER look at that Pic on Taboo's site...
Yes I did eliminated the PCV valve was I not supose to???
I sure couldnt find where the oil was coming from since as the sprokets spinned they spread oil all over the engine compartment. What should i do if thats the case "PCV"???
Would I need to reinstall it again??? Have I done any internal damage??? I forgot to mention that It was smoking white a lot. Thanks. :dsm: OMG
Do you think that if thats the case perhaps i have blown my valve cover gasket??? I hope thats the case I just got the dang car a month ago OMG :dsm: Thanks. I have seen your picture and they show a whole lot better of what an elimination should look like and I will go by your pics. If anything would you mind guiding me the right direction so that I dont blow anything away LOL ??? :( OMG
Just be CAREFUL with anything you do on these things - Research thoroughly - They aren't very forgiving of mistakes & will puni$h your dearly for them. Hopefully it's not hurt - Clean it up & keep us posted but you better put it in Problems or Newbie NOT TUNING & NOT ENGINE PERFORMANCE - & don't double-post or you'll get nailed.
1997RS said:
Gosh I feel greatful to have you guys I have posted this same ad in here somewhere else and I got basicaly the same deal. I eliminated the PCV and plugged where it went, then where the breather went to the intake I eliminated it too and took a Fuel filter (transparent) and basically put breather and pcv together i didnt even noticed this Geez i feel so STUPID!? LOL man Thank You. Do you think its only that and not something major??? i mean I guess I'll need another valve cover gasket (oh boy not again!) :rolleyes: George :dsm:
BINGO BTW!!
Thanks. I knew I was posting in the wrong locations and double wasnt good eother but got scared and wanted an answer quick too Thanks i will fix tomorrow and since I only ran it for less than 5 minutes it should be ok right? OMG
