Help, getting the rear shocks off! *pic*
PieEyedPiper
DSM Wiseman
5,580
65
Nov 13, 2004
North Bay Area, California
I'm doing a shock/spring install right now and so far the front has been cake (minus having to redo one side cause I didn't put the busihings on right). The problem is the rears. I have the bolt on the bottom removed but I can't seem to get the shock out. I've kicked it and pry'd with a bar but they hardly budge.
Here's what I mean. Am I going about this the right way, even? The vfaq and other sources describe this step as "now remove the shock" so I'm at a bit of a loss. Does the shock/mounting even allow for enough play for the shock to slide off that rod?
I just sit on the ground, and give it the biggest kick i can(usually about 10 of them) and it flys off, if not, heat it, then kick it again.
I've had this happen to me a couple of times. I would try the penetrating lubricant and hammer first, if that doesn't work you may have to use a torch and melt the bushing to get the shock off. Sometimes a small amount of heat from the torch will loosen it up and it will slide off, but I've had to melt the bushing a couple of times. I'm sure there are other techniques that work, but I don't have a lot of patience for stuck parts, the torch is usually my first choice. Good luck
If you unbolt the upper A-arm (at either end), you will be able to wiggle the entire knuckle, which often allows the shock to slide right off.
- Jtoby
ps. if you use a torch on the shock, please sell it on eBay or DSMtalk, not Tuners
All great advice. Thanks everyone.
I managed to get both side done using the lay on the ground and boot the living shit out of it, technique.
I was worried since I couldn't get it off by conventional means that I was going about it the wrong way.
Thanks for setting me straight. :thumb:
When I did ine I ran into a similar situation where the bushings in my control arms were tight and pushing up against the shock, or the shock pushing down on the bushing tension (whatever). I just applied weight to the hub gradually, constantly pushing in on the shock until I hit the G spot and the shock slid right out.
I imagine kicking the hell out of it will work too though.
heh i just ran through the same problem with my 1g. i ended up cutting the bottoms with a cutting wheel and then prying for awhile with a big screwdriver, cuting some more, prying, chizzling rubber, prying, getting tired, prying some more, kicking, coming inside etc etc etc
finally i got mine off, but i cut into the damn piece the bolt goes into by accident (with a hack saw at first) thinking it was all rubber and that the bolt held it in...might have to replace the whole thing now or grind off the cuts.
edit: when i say "just" i mean like 20 min ago.
