help!! driver window wont close!!!
Stainbox12
378
7
Jan 3, 2006
Panama, Central America
today my window stopped working, i checked the fuses and they are all good. the passenger window works perfectly, but mine won´t close, it doesn´t even move, what could it be. is there any temporary fix? i searched in the forums with no luck. sorry :sosad:
i cleaned all the contacts as the vfaq says, and that didn´t change anything, the passenger window still works though. any other suggestions? :confused:
sounds like your window motor is shot I agree with 95 talon owner. Hit the junk yard and hook your self up. Mine was having problems All I did was to clean the window tracks slightly and now it runs like a charm. So while you got everything torn apart clean it up.
Before you go to the junkyard..pull the motor out and test it. Hook it to a battery charger to see if it moves. If it does, look to the switch. If it doesn't, replace the motor. I have one for you if you can't find one.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
