Please Help !! Sunroof Wont Close
chico904
1,347
7
Feb 9, 2004
Pittsburgh, Pennsylvania
Hey guys, as the title says my sunroof wont close. It goes about a quarter of the way, jams, then goes back to being all the way open. I tries tightening all visible bolts, looked for something in the way, checked to see if its in the track :confused: even sprayed a ton of WD-40. If sitting inside, and looking up at the sunroof while closing, the part where it jams is on the right side. The "clip" (I don't know the real part name" that holds it in the track goes backwards , and at that point it jams. The left side clip never goes backwards. Any ideas?
I had some sunroof problems and found with mine if I undid the screws and took it off the thing would close all the way and then I could screw it back on and it would be shut. Of course this is a temporary solution as mine probably won't close if I try and open it again.
Yeah, I tried doing that before I had to go to work, unfortunately, one of them was stripped so I Didnt have enough time to try to get it off. Thanks though, I'll try again tomm.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
