window will not close
Dr Vic
107
Aug 30, 2007
Dallas, Texas
somebody smashed my driver side window. I had the window replaced but it wouldnt close all the way unless i put pressure on the window from the outside. Ive already replaced the regulator and same problem. Ive tried loosening and tightening the regulator bolts without success. I dont think the tracks are damaged. any tips on how to fix this?
take the door panel off and make sure your glass is in the window run channel and if it is try spraying the channels with some silicone . if that doesn't work then the motor will have to be replaced .
I found the solution. It was the replacement window. your typical replacement window is around 1 to 2 mm thicker than the stock one. Once I replaced the window with a stock one the window was able to roll up
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
