help: car randomly does not start
ronf119
Feb 25, 2003
i've had this random starting issues for a few months now...there would be days where the car will start fine and then some days where it would be hard to start. on the times that it would be hard to start, all i would hear is 1 click when i turn the key and that's it. you don't hear the engine crank. eventually after like 5-15 tries of turning the key, the car would fire up with no problems. do u think it's a starter issue? i'm pretty sure it's not the battery as i changed it just a month ago and i've been having this problem even before the battery change. any help.
I've personally see it result from a couple of problems. On my dad's car it was a sign of the starter taking a crap, which was replaced to fix the problem. On my friend's GST, it was an issue with corrosion on the wiring at the + battery post (not visible just looking at it). After we cut and recrimped all of the wire to all new terminals (including battery terminals), and cleaned the battery post, everything was back to normal and better.
Also check the ground wiring on the starter. Sometimes this can corrode or become loose and cause problems.
i'll try some of the suggestions when the weather improves here in chicago...anyone else have any ideas
could be your balance shaft sencer. . .mine was doing the same thing cost me 700 becasue i busted something that hendle oil and then it got all over mine belts. So you should have it looked at soon because things like that only get worse.
ouch..lets hope that doesn't happen...i'm saving money to rebuild my head wiht some fp2 cams or hks cams when i'm due for a timing belt change in a few months
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
