HELP!! Car doesn't have spark
PSiedTSi
May 26, 2004
Moorhead, Minnesota
first off i have a 92 talon tsi awd 5spd 6bolt, i bought it from a guy that owned a shop and used it as a dynoqueen and he took the motor out before he sold it to me. He was running VPC and MSD ignition. I got a JDM motor and put it in...everything plugged in alright...it was a 90 motor so the cam sensor was different so thats one of my possibilities is that its wired wrong. Are there any stock ignition wires that had to be cut for the MSD to be installed? What is the wiring diagram for the 90 camsensor to a 92 harness? Another problem could be a bad ECU...if anyone is near fargo, nd-moorhead, mn and would like a possible challenge let me know ill pay and provide the booze...let me know any possibilities or if you wanna help
Thanks,
Tony
Thanks,
Tony
I THINK I AM HAVING THE SAME PROB, SO IF YOU FIND A SOLUTION, PLEASE LET ME KNOW
Do me a favor... Go over you ECU wire harness..... Pull them out, check for loose wires Etc... Most important, if there is anything wired to the ECU... CHECK to makesure the tapped correctly... I had TEE taps on.. It lowered the voltage soo bad, my car wouldn't start. NO SPARK, FUEL not alot (like drips)....
Check that.. Then repost
