Help Can i still use this water pipe
duy35
102
May 25, 2010
harrisburg, Pennsylvania
This water pipe has a kink in it. Is it still good enough to use?
Can you use it? Sure
Will it restrict coolant flow? Definitely
Will it leak from the end? Most likely
Would I use it? No
Based on what I see, no. A picture of the whole pipe at different orientations would help, though, as I may be imagining the rest of it wrong.
thats the water pipe that hooks into the water pump and then hooks into your lowwer radiator hose correct? that metal water pipe isnt hard to change. i say put it on and try it. if it leaks it aint a big deal to pull it back out and go find a new one. i dont think the dent in it would cause that big of a restriction. but idk....
Ill speak from experience and that pipe blows to change! The seals on each end are oversized to seal well and difficult to get out. I would get a replacement and only change it once.
Zero
Get a used or something. Maybe $10-$15 at the local 'you-pull-it yard' You can try straightening the sealing end for where the hose clamps on, but its just not going to seal up right. A lot of people end up putting a dent in that waterpipe to run a holset turbo and it still functions fine, but.... that is no dent. Thats a big honkin' kink. I'd be worried about flow at that point.
