help building usb datalogging cable
92gsxbafaro
256
24
May 20, 2011
Spokane, Washington
To answer your question about building one from a 4 wire USB, the answer is no. I just recently tried making one like that with a 4 wire. If you look at the data sheet (which I failed to do before building mine) in the writeup about that cable you will see that is has a chip in it. This is to convert the signal from RS-232 (Serial) to USB. Without that chip I am pretty sure a standard 4 wire will not work. Another possible solution would be to create the cable out of a serial cable, then get a serial to USB converter that plugs into your computer.
As far as yours not working goes, do you have the drivers installed for the cable? Most of the time when a computer wont recognize something its usually a driver issue.
hi i tried to make a usb datalogging cable off of this thread
http://www.dsmtuners.com/forums/art...6-easy-way-make-1g-usb-datalogging-cable.html
i cant get my laptop to recognize the wire when i plug it in im not sure what im doing wrong. if someone could help me i would really appreciate it.
also can i use a 4 pin usb cable to make it?
Most the magic is in the first line item in the parts list. QTY-1 FTDI USB to RS232-WE-1800-BT_0.0 (Available @Mouser Electronics) USB-RS232-WE-1800-BT_0.0 FTDI Cables (Cable Assemblies)
You must use a FTDI based USB to RS232 adapter. It's not just a simple USB cable with the end cut off. The FTDI chip inside speaks the USB protocol and outputs a RS232 signal that the other parts shape into something the car understands at the right data rate for a 1G ECU.
