HELP Boost leak
95GSTGuy
Jul 7, 2004
Fort Lauderdale, Florida
How would i know if i have boost leak, some one said it might be boost leak cuz my turbo spools up at 4500 RPM's i don't know all i know is that my car needs to get tuned bad so i thought that was it :confused:
1. What is a T04E turbo? That's like saying I have a 4 cylinder car. :)
2. Are you venting?
3. Your stock fpr is probably being overrun by the 255 pump.
This is what I have noticed with a quick glance of your profile, whether you have spooling problem depends heavily on which turbo you have.
Its from Master Powers Turbo T04E 50 trim and wut u mean venting
A typical 50 trim should spool between 3800-4200 though the Master Power 50 trim isn't a typical 50 trim so I can't tell you for sure. If a boost leak test was not done after the turbo install, you probably have leaks. Perform a leak test and you should be able to get that down to 4200.
Is your BOV recirculated back to the intake pipe?
