Help Base Timing, MAFT
cammons
42
May 21, 2012
FORT LEE, North Carolina
Hi , i just bought a 2G Eclipse, The problem im having is Finding Base timing.
Its a 1g Engine and it has a 2g Intake manifold, It is also using a 3" GM Maft, Version 1.7
2G ECU, I need to know how to get the correct base timing using the 2G ECU.
2nd Id like some guidence on what to set the GM MAFT Rev 1.7 , I have 450CC injectors, and the ECU is Chipped and the lable on the chip says "( 98 75/60/GSX KNOCK 650cc 10.5:1, 14Degrees )"
The car idles with settings as follows
AUX=0
Modes 1=off
2=off
3=off
4=off
Base=6
Idle,Mid,Wot=0
Appreciate any guidence or help
My ECU is 2G, I Believe
Oh heres something New, i looked in the ECU and Found a EPROM Chip that had a sticker that said This (98 75/60/AWD Knock 650cc 10.5:1 14degrees)
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
