help! alarm wont turn off..!
se0nz
78
Nov 18, 2008
Baldwin Park, California
so i finally finished my FMIC install and the negative terminal has been unplugged for about 5 days and now when i plug it in the alarm is going off like crazy and unlocking the doors or locking them with the key wont turn it off... i dont think this is the factory alarm and i dont have the remote... any ideas? i'm so pissed i can't drive the car after all my work! :cry::cry: :mad::mad:
You can also put the key in the ignition and turn it to the ON position. then find the Valet button and press it (maybe hold it). This will put the alarm in Valet mode and make it STOP.
Lol mine is flipping out too. But mine just goes off randomly. Im at work and noone touches my car and it is going off. I wake up this morning to go to work and it is going off.... Alarms these days!
Mine used to do this. It was because the alarm switch for the hood wasn't getting pushed down. Try bending it up a little or putting a couple washers under the bracket to see if that helps.
Thanks for all the replies everyone... i switched the ignition to on and plugged the battery back in and it stopped, works fine now except i think i have a boost leak somewhere. the car sputters a little as the rpms go up and just misfires around 10lbs of boost and probably around 3500 rpms, the car bucks and dips forward pretty harsh... i know it's not fuel cut though hehe. i really doubt it anyway, i was running 15psi on the sidemount just fine with my 14b stock injectors and stock fuel pump and i know just adding the fmic wouldnt do that... too bad work gets in the way of me working on the dsm! :dsm: :rolleyes:
