[Help] 14B/16G Ebay Install Kit J-Pipes
CONSIGLIERI
181
Oct 6, 2010
Columbia, South Carolina
Hello friends ! I've done some research here, but I wanted some fresh opinions about the EBAY 14B/16G install Kits, preferably because of the J-Pipes. Also, all the links in previous topics where dead due to the unlisted products.
I'm using a stock FMIC on a 2G.
I know some say that the Oil lines and hoses/couplers that comes with those kits are JUNK, so I'm buying them mostly for J-Pipe and Lower Pipe.
Also, Is there any difference between the J-Pipe that is used with a SMIC or a FMIC ?
Oh, sorry, one more thing. I will buy new silicone couplers. Will teh 2'' do the work ?
The most "famous" J-Pipes are the ones from CX Racing. Do they align correctly ?
CXRacing Eclipse Talon Laser DSM 2G TURBO Install Kit TD05 16G Turbo J Pipe | eBay
Other Kits:
95-99 MITSUBISHI ECLIPSE GST GSX 16G TURBO J PIPE KIT | eBay
GSP DSM TURBO INTERCOOLER J PIPE 4G63 D32A D33A (FOR 16G AND 20G) PERFORMANCE | eBay
MITSUBISHI DSM ECLIPSE TALON LASER 1G 2G 4G63 16G TURBO J PIPE KIT - Union Performance - Auto Parts Store
EXTREME PSI
EXTREME PSI : Your #1 Source for In Stock Performance Parts
Sorry for another post about 16G install Kit, but I couldn't make my decision only looking at the older threads.
another question on this topic..
will the stock j-pipe and lower ic piping that would bolt to the t25 bolt to the 16g?
reason being i was wanting to get a j pipe fr a fmic seeing as how ill be putting one on at a later stage.
looking at install kits on extremepsi btw
So you want a j pipe for your t25, and later a 16g correct, extreme psi has some nice stuff depending on what you want to do. I used to run a j pipe but it was for the fmic, and i ran a stock j pipe for the smic.
no installing a e3 16g now but not the fmic yet.. but the kit comes with a j pipe so i was wondering if the stock one will bolt to the 16g so that i can get the j pipe for a fm with the kit for later use.
Im not exactly sure i ran my old evo with a stock j pipe for the smic, thats it, aftermarket j pipe was used on my fmic, but now my turbo has no j pipe.
a stock j pipe for a smic, im pretty sure they are way smaller in diameter. if you ever use a stock j pipe on after market intercooler piping, may cause a problem unless it is the same diameter. If its not the same, it may cause a "bottle neck" effect. i would go with an aftermarket jpipe with a FMIC. and just my opinion i would go with a jpipe that has a boost line nipple preinstalled so you dont need to install one yourself. and if its not needed. just cap it off.
The diameter of the stock j pipe is no smaller than the outlet on the turbo. IT really isn't a restriction at all.
ok, may just be my opinion i go with same size piping all the way around. matching different size piping with (2.5 - 3) or vise versa couplers is just not my thing unless i absolutely have too. in which i dont have too soo. just my .02 cent
A lot of make mistakes, even when reading throug some of the threads, some are long, and some are hard to figure out. You could find a j pipe for now and install later i ran my smic for with my evo for a while, my ebay j pipe didnt work out too well. but ets has a nice i kit, i run a pr core and custom piping i made, two couplers for the maf, two for the core, and, and a 45 degree reducer. All short route.
Are you asking if you can use the stock j-pipe off the t-25 on a 16g? If so , no you cant because the t-25 does not have a j-pipe.
:ohdamn: now that u say that and i actually LOOK under the hood i realize iv waisted everyones time. my bad
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
