daren_p
DSM Wiseman
- 4,604
- 98
- Nov 22, 2004
Newmarket,
ON, Canada
Here's the deal, my current setup is a short route Victory Performance FMIC & FP3052 turbo. The turbo outlet is the standard down firing setup, mated to a silicon elbow, which attaches to the IC pipe that runs at the bottom of the rad, over to the drivers side IC core inlet. With the 3052 turbo, Iam no longer able to run a lower factory heat shield. The IC pipes are aluminum so I was wondering what people think would be better, to wrap the LICP with some of that silver reflective heat shield material or leave it?
I have arguments for both methods. If I wrap the pipe I will insulate it from the heat coming off the turbine housing but I'm wondering how much this will actually effect the pipe air temp? My other thought is maybe leaving it bare will dissapate some of the heat generated from the turbo? So what is going to be the hotter heat source, the radient heat generated from the turbine housing thats about 6" away at the closest point, or the heat generated from compressing the air & not being allowed to dissapate? I would prefer answers from real world experience & not people just guessing either way, thanks.
. I was thinking that the LICP would typically still be moving air that is cooler (even though the compression has heated it up some) relative to the air surrounding the outside of it in that portion of the engine bay thus making wrapping it a good idea. But now knowing that the car is driven primarily during the summer puts a different twist on the whole thing. Sorry, I know that's not very helpful.
