1G Heat/AC Air flow control not working
91-talon-tsi
52
Mar 29, 2010
Ada, Oklahoma
The car is a 94 eclipse base with 1.8 sohc. The heat and a/c work, but for some reason the air flow control will not switch between legs, body/legs, defrost, etc... It's stuck on body/dash vents. What could be causing this issue and how can I fix it ? I'd like to fix it so I can use the defrost in the winter.
Pulled the radio out of the dash and found that the cable going to the dial for the air flow selector wasn't being help in place properly and was causing the dial to not function properly. Clipped it all back in place and it's good to go now ! :hellyeah:
