2G Headlight replacement
Tara
Mar 16, 2021
rowlesburg, West Virginia
Hey all!
I have a 95 eagle talon tsi, and I need new headlights! As I expected, there seem to be limited options. I was just wondering if anyone has any suggestions of replacement headlights or solutions!
The headlight's seals are no longer good, and there's cracking in the plastic, so they fill with water and are always fogged up.
You can always remove them, seal them back up with a good sealer and then polish the lens. Is the cracking a "hazing" or are they physically broke?
HERE is what I did with my 1g headlights.
You should be able to find a set. Lots of 95-96 people convert to the 97-99 front end. Post a WTB ad! :)
An additional note. When polishing the lens start at 300-500 grit and work your way to ~3000 to get a good polish. Soap and water is enough to clean and polish. Once done, look on Amazon for McGuires Headlight protective coating, cheap find, and put a coat or two with time in between on it - this will last a year so find a good date to remember. If you can get a hold of the manufacturer grade stuff then awesome, just do not use wax as this will cloud up much quicker than the McGuires.
