header
timsturbotalon
115
Nov 19, 2008
blacksburg, Virginia
i was just wondering about the ebay turbo headers. they good or bad? i have a pacesetter now, but it just crack around one of the pipes. and when u weld them back up the crack again.
it just depends on witch ebay header i have a ebay header and it works fine it also has braces so it is not prone to crack but it was s.s. and polished it only stayed that way for about a week now its polished purple
so would would a stainless steel hold up to the job. just going the cheap route for now. prob not good idea, something to last to around tax time
i had an ebay t3 manifold on my car when i first started moding, it cracked within 250 miles. If i was you i would get a 2g exhaust manifold. It will last forever. They are also cheap to come by and it will do a better job that something that is prone to cracking. Then save up and get a fp manifold, hafe, or punishment racing manifold.
well i have an evo 3 manifold. but the header flows much better guess i will just get a cheap one for now cant be no worst then the pastsetter it was just a painted on this time i will get stainless.
i have a punisment racing manifold. Its tubular stainless but its not like a regular manifold its cast stainless pipe angles that are welded together. Comes with a life time warranty flows great.
if you have an evo 3 run that, that will flow very well and will work with your current mods and get you to your goal no problem. take the money you were going to spend on a header and get some fuel mods.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
