head salvageable?
volcakid8787
34
Feb 25, 2009
Colorado Springs, Colorado
I recently reinstalled a refinished head on my 1g to find out that I did the timing wrong and seized my engine. I trusted my mechanic friend with this part of the job and, needless to say, we got it wrong. An expensive mistake, I know. Anyways, I just got everything ripped apart again to assess the actual damage. Cylinder three and two have the damage. The valves snapped off, got stuck in one of the pistons and scrapped the head. My question is: are these parts salvageable or do I need totally new head and totally new pistons?
Can you provide us with some pictures? Anytime you remove and reinstall timin belt you must turn the engine over by hand serveral times and double check that all timing marks fall back into place. You never ever just throw the belt on and go straight for them keys and start it. Post up some pics of the damage. More than likely you smoked it
Yes, thank you. That is very good advice. I have already posted on this and that's exactly the recommendations I was given. Anyways, here are some pictures:
Honestly I would not try to fix that head. For the price that you would pay to fix it, you could get another good head so its not worth the hassle. Also, this did not happen at idle...did it?
I don't see how you'd repair the head without grinding it down and losing compression. It's pretty much shot IMO. Pistons as well. Time for upgrades.
They can add the material back to the head with welding and machining, but since it's not exactly the rarest cylinder head in the world, I think it would be a waste.
As for the pistons, probably not a chance.
This was at idle. I had the head resurfaced and messed up the timing, thus the problem you see above. Thanks for the input yos!
