Head/Mani stud stripped. How to fix???
93jdmlaser
242
Sep 1, 2004
Cherry Hill, New Jersey
Im sure someone has had this problem before. It is the 2cd stud on the lower pass. side. The stud threads in but just keeps spinning and wont get tight. I tried to JB weld it in but that didnt work. The weld did not bond to the head just the stud. How can I fix this. I dont want to have an exhaust leak. Is there a heli coil kit for this and is there any other way besides that to get it to stay tight in there. Someone help me out. Thanks
Yea I went to the hardware store and picked up a 3/8in 24 tap and drilled out the hole and tapped it. Do you think I should just run a grade 8 3/8s bolt or cut the head off the bolt and make it a stud?
