head gasket replacement
lou schmouder
271
Jun 17, 2008
dalton, Georgia
Do I need to spray that copper gasket on my cometic head gasket??? also need to know retorque spec on my arp head stud ??????
You don't need to spray the copper spray on the gasket, technically. Is the gasket new? Are the head and block surface finishes good enough for a MLS head gasket? Which ARP's do you have? The standards or the L19's? Are you using oil or Moly Lube?
oem mls gasket without using anything else is the general consensus.
I tq my studs to 110( much higher than what the books say )youmust tq down in the proper order as well. :rocks:
