Head gasket problem. Help
zachernest24
May 13, 2013
Poteau, Oklahoma
Ok so I was heading to the mall and looked down and coolant temp was fine then about two minutes later it was overheated needle to the top. I pulled over to check and my hoses were filled with pressure and overflow bottle sounded like it was bubbling. So I checked it after it was cooled down. And there was maybe a contact case amount of antifreeze in it and it was sorta brownish. I talked to a buddy and he said I was in the early stages of a blown hg. I asked a shop what kind of hg I should get and he said cometic mls. But my friend and everyone else says not to. I am currently running 22 psi at 409 hp. What should I do? I looked on others with head gasket problem but they say different stuff. I have a 62mm precision turbo. Please help.
If the block has not been recently decked, stay away from a MLS HG.
Grab the OE or Felpro Composite (9627PT)
If you check some you will see where the OE and Felpro have gone 500hp and 30psi+
Have you found what caused the coolant issue?
A blown HG is not the cause of a problem, but the result of one.
Have the head checked for warp.
I plan checking for warping. I haven't done anything yet to fix it just deciding what I plan on doing. What could be some causes for the issue?
Any sort of leak in the coolant system. With the way you went and over heated, you had a sudden loss of coolant, so it sound like something busted. Hose would be my first guess.
None that I saw. I did busy a hose before but installed hps hoses for my coolant. And I didn't see any. And if I was leaking: wouldn't I see you smoke from hitting my exhaust ?
you might just be leaking, i was leaking from my radiator cap on the bottom,
but it leaked so little i didn't notice until it over heated. i freaked but i flushed it
and re checked it, and now it runs fine
I'll try to check when it's not snowing. Prob a dumb question how do I flush it ?
May be retorqueing the head studs May help, had my coolant reservoir bubbling after a pull, a retorque solved the problem
Yeah they were working
so i talked to a buddy and he said i may have something more than a blown hg since my compression was so low. What are the chances I have bad rings as well?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
