Head gasket help
Wanagofast
108
3
Nov 12, 2013
Newman lake, Washington
So i'm currently trying to figure out head gaskets. I was debating on fel-pro, oem or cometic. I really don't know what to pick? I'm using it for a daily but want to run 300-350whp safely. What should i look for in thickness? What other things should i look for?
Oem composite HG and arp head studs and you can't go wrong bro! If your planning to run higher boost and want even more seal go mls and l19's! Just remember if you use a mls you need to have the block decked and head machined so both are perfectly flat, so the mls will seal properly! But I would run the oem composite Hg and arp's for your power goal!
+1 on the OEM HG and ARP studs. Your power goal isnt beyond the point that it needs an MLS and machine work, so an OEM gasket with some good arp clamping pressure should do you quite well.
Also, a buddy of mine had about 300 awhp on his 2g w/ a Felpro gasket and ARP studs.
Alright thanks guys! Are all stock head gaskets interchangeable between 6 bolt and 7 bolt?(Due to my 6 bolt block and 7 bolt head)?
