head gasket help
tonypanda
300
Jan 18, 2011
murphysboro, Illinois
im replacing the head gasket on my 95 talon esi 420a and i cant get the bottom pulley off whats the easiest way to get it off im trying to get it done asap so i can get it running again
i already have the valve cover and motor mount off but i cant get the bottom pulley off and do you have to remove the cams to get to the head bolts?
I wanna say when I did mine I had to loosen the bolt but not take it out all the way, then use a pulley puller to get it off. It was a pain in the @ss.
yea so far it has been a pain in the a$$ seeing as i cant find my puller and i gotta get it done asap
Perhaps you should be more organized and have better time management.
Do you have a service book in front of you so you know the torque specs of everything you are pulling off and where parts go? Only asking because you were asking if you need to take the cams out to get to the head studs.
well i just didnt know if i had to and yea i have a booklet thing that tells me how to i just gotta find my puller now
    • george bromwell
    • pma1123
    • Sdcryan1
