4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
I had a built head installed on my tsi AWD 6 bolt project that I never completed.
I went to remove that head and spent at least a good 15 minutes trying to pull it up thinking that I was just feeling weak that day.
Turns out that I could not remove the head without pulling the ARP head studs and washers. The head was a 1g 7bolt head with the holes reamed out so that the 6 bolt studs would fit.
Once I pulled the studs and washers it was so easy to pull the head.
This doesn't seem right. It bothers me that I had to disturb those head studs that were torqued in properly with the correct ARP lube.
I don't want to go through this when I pull the head on my GVR-4.
Pointers? Does that seem right? Thanks!
