HE351VE, We are for the big...
casuprock
320
3
Apr 13, 2010
Exeter, New Hampshire
HE351VE, the final frontier... Let me know what numbers this beast can put down from a built 2.3L stroker. Whenever I get around to finding out, I'll buy the closest guess a beer...
690hp
It's a 7-blade HX40 compressor mated to a HX35-sized turbine wheel in a VGT turbine housing. At best you're going to see 68-70 lb/min of airflow, which is good enough for 500-700hp depending on tune and boost pressure.
The real benefit will be the VGT system if you can make it work properly. You'll have a HX40 that could literally spool as quick as a 16G if the VGT system is operating properly....if that's the case, nothing on the market will touch a 70 lb/min turbo that would reach full boost under 4000rpms.
What would it take to make the VGT system work properly? If its feasible why aren't more people doing it?
I believe a VGT controller is in the works. There's a thread on the turbo talk forums where I guy put one on his 2ga gst. I would like to get my hands on a HE351VE.
Better question... Supposing this works, how would I reach the possible power levels without a welded center diff or stripping first/second/third gear into nubs? RadDsm might have a point. ROFL
I work with some people who do PVD coating on cutting tools- this might be a coating option for reducing gear friction . Also, cryo and nitriding are options for painful $
There are threads on this forum where a couple guys have run these on their cars.
http://www.dsmtuners.com/forums/turbo-system-tech/323774-holset-he351-vgt-goin-my-car.html
The bottom line is you cannot actuate the VGT using the electronic controller that comes on the turbo because your car is not equipped with a system that monitors the engine load, throttle position, turbine shaft speed, and boost level in relation to the VGT position.
Anyone who has done this so far has used a wastegate actuator to control the VGT through vacuum / boost pressure.
It sure won't be easy. We'll see what I can do with her... I think I can make a control system for this beast. I got the motor running this morning.
YouTube - HE351VE Motor Control
If you can figure out some way to control the VGT electroncially and use ECMLink to control it, that would be awesome.
My company makes electronics so I will build a controller that plugs into a pressure sensor and controls the vane positions based on boost pressure. Throttle position might also be a good control variable.
Here's the problem:
Concurrently tuning air/fuel and the VTG will be very difficult if one of the systems is not closed loop... air/fuel will have to be closed loop to keep the system at stoich and eliminate the variable. Otherwise, tuning could be an exercise in tail-chasing.
Possible solution:
Install a closed loop air/fuel management system like AEM to keep the AFR at like 12.7 or something?
Any ideas on the air/fuel solution would be helpful, I have an AEM uego wideband I got from my friend Kevin so that's why the AEM idea came up.
Here's the problem:
Possible solution:
Using a maf based air meter will keep afr's rock solid, no matter what the VE changes are from the changing turbine a/r.
will this be faster reacting than the wideband? the time constant of resistive maf sensors might be a concern. I'm not familiar with how fast a maf will respond to changes in flow. it's probably dependent on the resistor size, maf diameter, flow rate, etc.
